Page 2 of 4
Re: 3.7?
Posted: Wed 30. Aug 2017, 11:50
by EA3HOE
DL2RUM wrote:Radio doesn't follow the band change in WSJT-X.
Does the radio follow RUMlog? Can you command the radio to QSY?
Yes, that works. For example, when i click on the bandplan or DX Spots the radio follows.
Re: 3.7?
Posted: Wed 30. Aug 2017, 13:33
I don't have a Kenwood available. I tested the TS-590S interface with my KX3, without any problems. The KX3 reacts like a Kenwood for the major CAT commands.
We should wait for other Kenwood users.
Re: 3.7 CAT control WSJT-X and Kenwood TS-590S
Posted: Wed 30. Aug 2017, 13:41
by EA3HOE
Ok. No big issue for me at the moment. Just an inconvenience. BTW, i tried to run TCP2Serial you gave me a long time ago, but this crashes on start. Maybe something went corrupt. Maybe it just doesn't run on Sierra. Have you ever encountered that?
Ton.
Re: CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Posted: Wed 30. Aug 2017, 13:47
Yes, here it crashes since I use ipV6 local here.
Posted: Wed 30. Aug 2017, 13:57
by EA3HOE
No IPV6 here, so it must be something else.
Posted: Wed 30. Aug 2017, 14:25
Maybe. In fact, getting the external ip address lets the app crash. Do you need an update?
Posted: Wed 30. Aug 2017, 14:27
by EA3HOE
DL2RUM wrote:Maybe. In fact, getting the external ip address lets the app crash. Do you need an update?
If you have one, yes please. Maybe i can troubleshoot the issue i'm having.
by EA3HOE
Posted: Wed 30. Aug 2017, 14:56
Posted: Wed 30. Aug 2017, 17:07
by EA3HOE
Still crashes...
Process: TCP2Serial [3676]
Path: /Applications/TCP2Serial.app/Contents/MacOS/TCP2Serial
Identifier: de.dl2rum.TCP2Serial
Version: 1.1.4 (6)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: TCP2Serial [3676]
User ID: 1829133891
Date/Time: 2017-08-30 19:05:05.591 +0200
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: A8C78AFA-A78D-C0F6-E7F5-2E3AA66A857B
Time Awake Since Boot: 10000 seconds
System Integrity Protection: enabled
Crashed Thread: 6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Invalid parameter not satisfying: aString != nil'
terminating with uncaught exception of type NSException
abort() called
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fffa58042cb __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffba61448d objc_exception_throw + 48
2 CoreFoundation 0x00007fffa5809042 +[NSException raise:format:arguments:] + 98
3 Foundation 0x00007fffa7251be0 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 195
4 AppKit 0x00007fffa32a0dcd -[NSCell _objectValue:forString:errorDescription:] + 177
5 AppKit 0x00007fffa32a0c72 -[NSCell setStringValue:] + 41
6 AppKit 0x00007fffa334f91e -[NSControl setStringValue:] + 135
7 TCP2Serial 0x000000010a2f04b7 TCP2Serial + 46263
8 Foundation 0x00007fffa719d8ad __NSThread__start__ + 1243
9 libsystem_pthread.dylib 0x00007fffbb11393b _pthread_body + 180
10 libsystem_pthread.dylib 0x00007fffbb113887 _pthread_body + 0
11 libsystem_pthread.dylib 0x00007fffbb11308d thread_start + 13
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffbb02134a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffbb020797 mach_msg + 55
2 com.apple.SkyLight 0x00007fffb73073b7 SLSDisplayGetRefreshTiming + 212
3 com.apple.AppKit 0x00007fffa393a3e9 +[NSDisplayTiming(NSDisplayTimingCreation) displayTimingForScreenNumber:] + 17
4 com.apple.AppKit 0x00007fffa36a5941 __37+[NSDisplayCycle currentDisplayCycle]_block_invoke.31 + 467
5 com.apple.CoreFoundation 0x00007fffa5799d37 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
6 com.apple.CoreFoundation 0x00007fffa5799ca7 __CFRunLoopDoObservers + 391
7 com.apple.CoreFoundation 0x00007fffa577a6d9 __CFRunLoopRun + 873
8 com.apple.CoreFoundation 0x00007fffa577a114 CFRunLoopRunSpecific + 420
9 com.apple.HIToolbox 0x00007fffa4cdaebc RunCurrentEventLoopInMode + 240
10 com.apple.HIToolbox 0x00007fffa4cdabf9 ReceiveNextEventCommon + 184
11 com.apple.HIToolbox 0x00007fffa4cdab26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
12 com.apple.AppKit 0x00007fffa3273a54 _DPSNextEvent + 1120
13 com.apple.AppKit 0x00007fffa39ef7ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
14 com.apple.AppKit 0x00007fffa32683db -[NSApplication run] + 926
15 com.apple.AppKit 0x00007fffa3232e0e NSApplicationMain + 1237
16 libdyld.dylib 0x00007fffbaefa235 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fffbb02944e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffbb113621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffbb11307d start_wqthread + 13
Thread 2:
Thread 3:
1 libsystem_pthread.dylib 0x00007fffbb11348e _pthread_wqthread + 1023
Thread 4:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.SkyLight 0x00007fffb72b4aaf _CGSReenableUpdateForConnectionSync + 99
3 com.apple.SkyLight 0x00007fffb72c3dce CGSUpdateManager::enable_update(unsigned long long) + 532
4 libdispatch.dylib 0x00007fffbaecd524 _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fffbaec48fc _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fffbaeda9a0 _dispatch_queue_serial_drain + 896
7 libdispatch.dylib 0x00007fffbaecd306 _dispatch_queue_invoke + 1046
8 libdispatch.dylib 0x00007fffbaed3020 _dispatch_queue_override_invoke + 369
9 libdispatch.dylib 0x00007fffbaec66b5 _dispatch_root_queue_drain + 476
10 libdispatch.dylib 0x00007fffbaec648c _dispatch_worker_thread3 + 99
11 libsystem_pthread.dylib 0x00007fffbb1135a2 _pthread_wqthread + 1299
12 libsystem_pthread.dylib 0x00007fffbb11307d start_wqthread + 13
Thread 5:
Thread 6 Crashed:
0 libsystem_kernel.dylib 0x00007fffbb028d42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffbb116457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffbaf8e420 abort + 129
3 libc++abi.dylib 0x00007fffb9ae194a abort_message + 266
4 libc++abi.dylib 0x00007fffb9b06c2f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffba6166fe _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffb9b03d49 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffb9b037be __cxa_throw + 121
8 libobjc.A.dylib 0x00007fffba6145b6 objc_exception_throw + 345
9 com.apple.CoreFoundation 0x00007fffa5809042 +[NSException raise:format:arguments:] + 98
10 com.apple.Foundation 0x00007fffa7251be0 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 195
11 com.apple.AppKit 0x00007fffa32a0dcd -[NSCell _objectValue:forString:errorDescription:] + 177
12 com.apple.AppKit 0x00007fffa32a0c72 -[NSCell setStringValue:] + 41
13 com.apple.AppKit 0x00007fffa334f91e -[NSControl setStringValue:] + 135
14 de.dl2rum.TCP2Serial 0x000000010a2f04b7 0x10a2e5000 + 46263
15 com.apple.Foundation 0x00007fffa719d8ad __NSThread__start__ + 1243
16 libsystem_pthread.dylib 0x00007fffbb11393b _pthread_body + 180
17 libsystem_pthread.dylib 0x00007fffbb113887 _pthread_start + 286
18 libsystem_pthread.dylib 0x00007fffbb11308d thread_start + 13
Thread 7:: com.apple.NSURLConnectionLoader
2 com.apple.CoreFoundation 0x00007fffa577b434 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fffa577a8c1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fffa577a114 CFRunLoopRunSpecific + 420
5 com.apple.CFNetwork 0x00007fffa48b7734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fffa719d8ad __NSThread__start__ + 1243
7 libsystem_pthread.dylib 0x00007fffbb11393b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffbb113887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffbb11308d thread_start + 13
Thread 6 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x0000700006b1b3d8 rdx: 0x0000000000000000
rdi: 0x0000000000009f03 rsi: 0x0000000000000006 rbp: 0x0000700006b1b400 rsp: 0x0000700006b1b3d8
r8: 0x00007fffbafb7650 r9: 0x00007fffbaf79a50 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x0000700006b1b560 r13: 0x0000000000000030 r14: 0x0000700006b1d000 r15: 0x0000000000000008
rip: 0x00007fffbb028d42 rfl: 0x0000000000000206 cr2: 0x00007fffc3df0128
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x10a2e5000 - 0x10a2fcffb +de.dl2rum.TCP2Serial (1.1.4 - 6) <5B442610-17B7-31D1-B814-8D55E088EE27> /Applications/TCP2Serial.app/Contents/MacOS/TCP2Serial
0x10f8c9000 - 0x10fa6ffff GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x10faae000 - 0x10fffdff7 com.apple.driver.AppleIntelBDWGraphicsGLDriver (10.25.17 - 10.2.5) <8633C1AB-7008-3B8B-8D6D-8E1DE49DD265> /System/Library/Extensions/AppleIntelBDWGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelBDWGraphicsGLDriver
0x110218000 - 0x110242fff GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x11024c000 - 0x1102cbff7 com.apple.driver.AppleIntelBDWGraphicsMTLDriver (10.25.17 - 10.2.5) <20DB0471-534D-3570-9E5A-AB052CF54E68> /System/Library/Extensions/AppleIntelBDWGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelBDWGraphicsMTLDriver
0x118ace000 - 0x118b0bdc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x7fffa224f000 - 0x7fffa224ffff com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffa2250000 - 0x7fffa2267ffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffa2268000 - 0x7fffa2781feb com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffa2782000 - 0x7fffa28f3ff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffa28f4000 - 0x7fffa2908ffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffa2909000 - 0x7fffa2cfffef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffa2d00000 - 0x7fffa2d16fff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffa2d17000 - 0x7fffa2d1dfff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffa2d1e000 - 0x7fffa2d32ff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffa2d33000 - 0x7fffa2ebafe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffa2ebb000 - 0x7fffa2f6dfff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffa2f6e000 - 0x7fffa2f6efff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffa322d000 - 0x7fffa4006ff3 com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffa4018000 - 0x7fffa4018fff com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffa4019000 - 0x7fffa4087ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffa4121000 - 0x7fffa4250ff7 libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffa4251000 - 0x7fffa429bfff libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffa42f8000 - 0x7fffa432bfff libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffa4398000 - 0x7fffa4442ff7 com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffa4443000 - 0x7fffa4494fff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffa4495000 - 0x7fffa44a4ff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffa44a5000 - 0x7fffa44f2fff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffa44f3000 - 0x7fffa452efff com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffa452f000 - 0x7fffa453afff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffa453b000 - 0x7fffa4747ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffa4748000 - 0x7fffa4748fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffa48b1000 - 0x7fffa4c8bfff com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffa4caa000 - 0x7fffa4fb3fff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffa4fbe000 - 0x7fffa5055ff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffa5076000 - 0x7fffa507cff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffa52a7000 - 0x7fffa5334fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffa5335000 - 0x7fffa5348fff com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffa5349000 - 0x7fffa5644fff com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffa5645000 - 0x7fffa56f2ff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffa56f3000 - 0x7fffa5b8cff7 com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffa5b8d000 - 0x7fffa620ffff com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffa6210000 - 0x7fffa6453ffb com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffa65b8000 - 0x7fffa65b8fff com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffa65b9000 - 0x7fffa660afff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffa660b000 - 0x7fffa68e6ff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffa68e7000 - 0x7fffa691afff com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffa691b000 - 0x7fffa6923ff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffa6924000 - 0x7fffa6a90ff7 com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffa6a91000 - 0x7fffa6b41ffb com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffa6b42000 - 0x7fffa6ba1fff com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffa6ba2000 - 0x7fffa6c12fff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffa6c13000 - 0x7fffa6c58ff7 com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffa6ce1000 - 0x7fffa6e2effb com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffa6e2f000 - 0x7fffa6e64ff3 com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffa6e65000 - 0x7fffa6ed6ffb com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffa6fd4000 - 0x7fffa6fd9fff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffa716b000 - 0x7fffa7511fff com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffa753d000 - 0x7fffa756eff7 com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffa762e000 - 0x7fffa76d1fff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffa76d2000 - 0x7fffa7768ff7 com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffa7769000 - 0x7fffa776fffb com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffa77c2000 - 0x7fffa7922fef com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffa7923000 - 0x7fffa7927fff libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffa7928000 - 0x7fffa7a18ff7 libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffa7a19000 - 0x7fffa7a3cffb libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffa7a3d000 - 0x7fffa7a64ff7 libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffa7a65000 - 0x7fffa7a67ff3 libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffa7a68000 - 0x7fffa7ab6ffb libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffa881f000 - 0x7fffa8838ff7 com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffa9018000 - 0x7fffa9073fff com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffa995c000 - 0x7fffa9964fff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffa9b3b000 - 0x7fffa9b43ff7 libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffa9b44000 - 0x7fffa9b92ff3 com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fffa9b93000 - 0x7fffa9bacffb com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffa9bad000 - 0x7fffa9bb8ff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffa9bb9000 - 0x7fffa9bbbfff libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffa9bbc000 - 0x7fffa9bbfff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffa9bc0000 - 0x7fffa9bc4fff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffa9bc5000 - 0x7fffa9bceff7 libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffa9bcf000 - 0x7fffa9bdafff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffa9bdb000 - 0x7fffa9c17ff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffa9c18000 - 0x7fffa9d8eff3 libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fffa9d8f000 - 0x7fffa9dd0ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffaa738000 - 0x7fffaa746fff com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffab298000 - 0x7fffab498fff com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffab9ff000 - 0x7fffabd01ff7 com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffabd02000 - 0x7fffabd77fff com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffabda2000 - 0x7fffabda5ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffac12c000 - 0x7fffac19bff7 com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffaea1c000 - 0x7fffaea3effb com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffaea3f000 - 0x7fffaea4efeb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffaeb3c000 - 0x7fffaebc797f com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffaeffa000 - 0x7fffaf078ff7 com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffafd03000 - 0x7fffafd2aff3 com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffb064f000 - 0x7fffb0658ffb com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffb0da1000 - 0x7fffb0db1fff com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffb10ec000 - 0x7fffb111cff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffb13ad000 - 0x7fffb143cff7 com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffb143d000 - 0x7fffb157cfe7 com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffb157d000 - 0x7fffb164dff3 com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffb169d000 - 0x7fffb1702ff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffb1703000 - 0x7fffb1711ff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffb1783000 - 0x7fffb178dffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffb178e000 - 0x7fffb1792ff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffb17c8000 - 0x7fffb183dffb com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffb1879000 - 0x7fffb18b8fff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffb18b9000 - 0x7fffb19cafff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffb1cb2000 - 0x7fffb20e3ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffb343a000 - 0x7fffb343afff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffb3447000 - 0x7fffb3452ff3 libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffb370b000 - 0x7fffb3727fff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffb3e38000 - 0x7fffb3eaeff3 com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffb44c9000 - 0x7fffb44d0ffb com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffb44d2000 - 0x7fffb44e6ff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffb44e7000 - 0x7fffb4509fff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffb45f0000 - 0x7fffb47a7fff com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffb50c8000 - 0x7fffb5141ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffb52bc000 - 0x7fffb52e4ff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffb5396000 - 0x7fffb53a1fff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffb5c79000 - 0x7fffb5cbaff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffb63a2000 - 0x7fffb63bcfff com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffb63d5000 - 0x7fffb63f8ff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffb7154000 - 0x7fffb71e1fff com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffb7202000 - 0x7fffb7468feb com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffb7647000 - 0x7fffb7653ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffb7d3f000 - 0x7fffb7db3fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffb81f2000 - 0x7fffb81f8ff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffb8284000 - 0x7fffb834aff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffb83be000 - 0x7fffb83bffff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffb83c0000 - 0x7fffb8550ff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffb9601000 - 0x7fffb9603ffb com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffb9658000 - 0x7fffb9673ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fffb9674000 - 0x7fffb967ffff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffb9711000 - 0x7fffb9712ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffb9713000 - 0x7fffb9926fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fffb994a000 - 0x7fffb994afff libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
0x7fffb994b000 - 0x7fffb994fffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
0x7fffb9950000 - 0x7fffb9951ffb libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
0x7fffb99bd000 - 0x7fffb99e8ff3 libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
0x7fffb99e9000 - 0x7fffb9a65fc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
0x7fffb9a69000 - 0x7fffb9a69ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffb9a6a000 - 0x7fffb9a7aff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffb9a7b000 - 0x7fffb9a89ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fffb9a8a000 - 0x7fffb9ae0ff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffb9ae1000 - 0x7fffb9b0aff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fffb9b0b000 - 0x7fffb9b1bffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffb9b1c000 - 0x7fffb9b32fcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
0x7fffb9b33000 - 0x7fffb9b33ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffb9b34000 - 0x7fffb9b35ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffb9bef000 - 0x7fffb9cd4ff7 libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
0x7fffb9e72000 - 0x7fffb9ec5ff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
0x7fffb9f42000 - 0x7fffb9f42fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffb9f52000 - 0x7fffb9f57ff7 libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
0x7fffb9f58000 - 0x7fffba04aff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffba04b000 - 0x7fffba270ffb libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
0x7fffba276000 - 0x7fffba277fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffba278000 - 0x7fffba291ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffba292000 - 0x7fffba2a8ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffba2a9000 - 0x7fffba551ff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fffba584000 - 0x7fffba5feff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffba5ff000 - 0x7fffba9d1047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fffba9d4000 - 0x7fffba9d8fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffba9d9000 - 0x7fffbaa0afff libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
0x7fffbaa27000 - 0x7fffbaa43ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffbaa93000 - 0x7fffbabe1ff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
0x7fffbacd6000 - 0x7fffbace3fff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fffbace4000 - 0x7fffbadd3fff libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
0x7fffbadd4000 - 0x7fffbadfdfff libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
0x7fffbadfe000 - 0x7fffbae0fff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffbae1e000 - 0x7fffbae22ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffbae23000 - 0x7fffbae2dfff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
0x7fffbae2e000 - 0x7fffbae35fff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffbae36000 - 0x7fffbae3efff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffbae3f000 - 0x7fffbaec2fdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
0x7fffbaec3000 - 0x7fffbaef4fff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
0x7fffbaef5000 - 0x7fffbaefaffb libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
0x7fffbaefb000 - 0x7fffbaefbffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffbaefc000 - 0x7fffbaf08fff libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
0x7fffbaf09000 - 0x7fffbaf09fff liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
0x7fffbaf0a000 - 0x7fffbaf0fff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffbaf10000 - 0x7fffbaf12ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffbaf13000 - 0x7fffbaf14ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffbaf15000 - 0x7fffbaf2dff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffbaf2e000 - 0x7fffbaf2eff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffbaf2f000 - 0x7fffbafbcfef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fffbafbd000 - 0x7fffbafc0ffb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
0x7fffbafc1000 - 0x7fffbafc4fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffbafc5000 - 0x7fffbafddfff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fffbafde000 - 0x7fffbafe4fff libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
0x7fffbafe5000 - 0x7fffbb00eff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffbb00f000 - 0x7fffbb031ff7 libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
0x7fffbb032000 - 0x7fffbb079fe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffbb07a000 - 0x7fffbb098ff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
0x7fffbb099000 - 0x7fffbb0f2ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fffbb0f3000 - 0x7fffbb0fcff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7fffbb0fd000 - 0x7fffbb106ff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7fffbb107000 - 0x7fffbb10ffe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fffbb110000 - 0x7fffbb11aff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7fffbb11b000 - 0x7fffbb11eff7 libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
0x7fffbb11f000 - 0x7fffbb120ff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7fffbb121000 - 0x7fffbb128ffb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
0x7fffbb129000 - 0x7fffbb13cff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7fffbb13d000 - 0x7fffbb142ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffbb143000 - 0x7fffbb16cff7 libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 6262
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=249.8M resident=0K(0%) swapped_out_or_unallocated=249.8M(100%)
Writable regions: Total=131.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=131.6M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 8540K 5
CG image 84K 9
CoreAnimation 84K 8
CoreUI image data 2876K 14
CoreUI image file 184K 5
Kernel Alloc Once 8K 2
MALLOC 92.4M 41
MALLOC guard page 48K 10
Memory Tag 242 12K 2
SQLite page cache 64K 2
STACK GUARD 56.0M 9
Stack 11.6M 9
VM_ALLOCATE 112K 15
__DATA 20.6M 206
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 116.2M 8
__TEXT 133.6M 206
__UNICODE 556K 2
mapped file 55.4M 14
shared memory 16.4M 12
TOTAL 517.9M 565
Model: MacBookPro12,1, BootROM MBP121.0167.B33, 2 processors, Intel Core i7, 3,1 GHz, 16 GB, SMC 2.28f7
Graphics: Intel Iris Graphics 6100, Intel Iris Graphics 6100, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445424533303445422D45474346202020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445424533303445422D45474346202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
Bluetooth: Version 5.0.5f1, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Thunderbolt Ethernet, Ethernet, en4
Network Service: Parallels Shared #0, Ethernet, vnic0
Network Service: Parallels Host-Only #1, Ethernet, vnic1
PCI Card: Apple 57762-A0, Ethernet Controller, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: USB3.0 dual display
USB Device: External USB 3.0
USB Device: Bluetooth USB Host Controller
USB Device: USB2.0 Hub
USB Device: Hub
USB Device: CP2102 USB to UART Bridge Controller
USB Device: USB Audio CODEC
USB Device: USB-Serial Controller D
USB Device: Vendor-Specific Device
USB Device: USB Storage
USB Device: Samsung S2 Portable
USB Device: Jabra UC VOICE 750a MS
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Thunderbolt Device: Thunderbolt to Gigabit Ethernet Adapter, Apple Inc., 3, 5.5
